  2. Functional Verification
  3. Jasper Gold formal connectivity verification :: Reverse...
  • Subscribers 67
  • Views 18273
Jasper Gold formal connectivity verification :: Reverse connectivity generated report contains duplicate connections
anurag7883
anurag7883 over 7 years ago
I am using jg connectivity app to get the connection between to modules.
After compilation and elaboration of my design I am using following command
>> check_conn -generate_candidates -src abc -dest def -complexity straightforward -silent
where abc and def are module name. abc module has only one instance, whereas def module has two instances in design.
>> check_conn -generate_connection_map [check_conn -list candidate] -save_as pqr.csv -force -refine_candidates
The report has duplicates as following -
CONNECTION c_17 abc_inst source_sig[2] genvar_inst[1].pqr_inst dest_sig[0]
CONNECTION c_18 abc_inst source_sig[3:2] genvar_inst[1].pqr_inst dest_sig
\\ c_17 connection is duplicate of c_18.
How can i get a report which can remove all these kind of duplicates?
  • ckomar
    ckomar over 7 years ago
      Can you share the version you are using. This was a known problem some time ago but has believe to have been fixed
  • ckomar
     Can you share what version you are using? This was a known problem some time ago but was believe to be fixed.
