  2. Functional Verification
  3. Grammar of language E about check that
  • Subscribers 67
  • Views 18630
TaoZ
TaoZ over 7 years ago
Hi, all
I find the syntax of "check that" in Specman E language reference is as follows:
Syntax
check [[name] that] bool-exp [[then] true-block] [else dut-error-action]
So I can add some actions if the check succeed in the true-block, but result in compile error, could someone give me a hand, and tell me where it's the error. here is my code:
check that <list_name>.is_empty() then {
  out("list is empty");
else {
 out("list is not empty");
BRs
  • StephenH
    StephenH over 7 years ago
    The else branch has to be dut_error, not some arbitrary code (otherwise you would just use an "if" instead of "check".
    This works:
    extend sys {
    foo : list of bit;
    run() is also {
    check that foo.is_empty() then {
    out("foo is empty");
    } else dut_error("foo is not empty");
  • TaoZ
    TaoZ over 7 years ago in reply to StephenH
    Thanks Stephen, I think is the else dut-error-action, which, as you said, can only be the dut_error, is the reason of compile error. it seems dut_error statement can not be put in {} here.
    One more question, as the dut_error will terminate the simulation in an dut error, is there anything has the same function like `uvm_error in UVM that count an error, but the simulation continues?
  • StephenH
    StephenH over 7 years ago in reply to TaoZ
    If you name the check, then you can procedurally control it, for example:
    extend sys {
    foo : list of bit;
    run() is also {
    set_check_by_name("sys","FOOCHK",ERROR_CONTINUE);
    check FOOCHK that foo.is_empty() then {
    % specman -c "load check; test"
    Welcome to Specman Elite (18.10.001-a Build 318) - Linked on Mon Oct 22
    16:04:27 2018
    Protected by U.S. Patents 6,141,630 ;6,182,258; 6,219,809; 6,347,388;
    6,487,704; 6,499,132; 6,502,232; 6,519,727; 6,530,054; 6,675,138; 6,684,359;
    6,687,662; 6,907,599; 6,918,076; 6,920,583; Other Patents Pending.
    Checking license ... OK
    Loading check.e ...
    read...parse...update...patch...h code...code...clean...GC(sys)...
    Doing setup ...
    Generating the test with IntelliGen using seed 1...
    Starting the test ...
    Running the test ...
    *** Dut error at time 0
    Checked at line 6 in @check
    In sys-@1.run() (unit: sys):
    FOOCHK: foo is not empty
    Will continue execution (check effect is ERROR_CONTINUE)
    No actual running requested.
    Checking the test ...
    Checking is complete - 1 DUT errors, 0 DUT warnings.
  • TaoZ
    Hi, Stephen, that exactly I want to know, many thanks!
