  2. Functional Verification
  3. Viewing task values in Simvision
  • Subscribers 67
  • Views 26623
DylanC
DylanC over 7 years ago
I'm working on creating a robust simulation environment for a project and I'm not super familiar with Simvision/Incisive.  In modelsim you can view the values inside task calls the same way you view signals in modules.  Is there a way to do this in Simvision?  I'm thinking maybe it has to do with the $shm_probe command.  I'm doing $shm_probe(name, "ACM").
Is this possible with the Cadence tools?
Thank you,
Dylan
  • StephenH
    StephenH over 7 years ago
    Hi Dylan.
    In general we recommend not embedding waveform probing in the SV code, as it's less flexible than using the Tcl interface. With Tcl, there is a "probe" command which allows you to specify the hierarchy to send to the waveform file, and at the same time you specify the types of design objects that are included, e.g. just i/o ports, internal nets, assertions etc. This can optionally include tasks and functions as well as memories.
    For example: "probe -create -shm top.dut -all -depth all -tasks -functions".
    Full documentation here: https://support.cadence.com/apex/techpubDocViewerPage?xmlName=tclcmdref.xml&title=Xcelium%20Simulator%20Tcl%20Command%20Reference%20--%20probe%20-%202.35.4%20probe%20Command%20Syntax&hash=probe-probecommand:syntaxprobeCommandSyntax&c_version=18.09&path=tclcmdref/tclcmdref18.09/probe.html#probe-probecommand:syntaxprobeCommandSyntax
    If you really want to stick with $shm_probe, add "T" to the mode string. See https://support.cadence.com/apex/techpubDocViewerPage?xmlName=svsim.xml&title=Debugging%20SystemVerilog%20--%20Accessing%20Design%20Objects%20with%20Tcl%20-%20Probing%20Compilation%20Units%20with%20Tcl%20and%20System%20Tasks&hash=AccessingDesignObjectswithTcl-1057261ProbingCompilationUnitswithTclandSystemTasks&c_version=18.09&path=svsim/svsim18.09/Accessing_Design_Objects_with_Tcl.html#AccessingDesignObjectswithTcl-1057261ProbingCompilationUnitswithTclandSystemTasks for all the options.
  • DylanC
    DylanC over 7 years ago in reply to StephenH
    Hi Steve,
    Thanks for the very fast reply.  That worked perfectly!
  • DylanC
    One more quick question.  Can an automatic task's waveforms be shown?  I have an automatic task but when I drag it into the signal window nothing shows up.  If the task is static it works as expected.
  • Doug Koslow
    Doug Koslow over 7 years ago in reply to DylanC
    Hi Dylan,
    The simulator does not support probing of those. (It's a longstanding limitation.)
    For details, see the following Cadence Support article:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000siWaEAI
    Thanks.
    - Doug
  • DylanC
    DylanC over 7 years ago in reply to Doug Koslow
    Hi Doug,
    Thanks for the clarification.  That shouldn't be a big deal.  I don't use many automatic tasks.
