  2. Functional Verification
  3. Need Help to Know *W,WKWTLK "Waiting for a Exclusive lock...
  • Subscribers 67
  • Views 9530
Need Help to Know *W,WKWTLK "Waiting for a Exclusive lock" issue
mahee424
mahee424 over 7 years ago
 I'm using NCSIM v15.20.030 version.
  Have you seen the below issue while running regression with NCSIM; If so please share your feedback.
irun: *W,WKWTLK: Waiting for a Exclusive lock on file '/home/*/run/INCA_libs/irun.lnx86.15.20.nc/.ncrun.lock'. pid:120971
With the above error,the test couldn’t execute and went to block state.
Please help in this regard?.
Mahee.
  • StephenH
    StephenH over 7 years ago
    Hello Mahee.
    The answer to this is potentially complex, as it depends on your IT setup as well as the way you run your regression suite. Please login to support.cadence.com and look at the following article which describes the NFS locking and troubleshooting in detail: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nTG5EAM&pageName=ArticleContent
  • mahee424
    mahee424 over 7 years ago in reply to StephenH
    Hi Stephen,
    Thank you for sharing the article. I've to work with IT and do modifying the script accordingly.
