  2. Functional Verification
  3. cds.lib
  • Subscribers 67
  • Views 23085
cds.lib
fooyu
fooyu over 7 years ago
Hi all,
Anyone know how to define library in cds.lib?
Thanks and regards,
Yu
  • StephenH
    StephenH over 7 years ago
    Hello Yu.
    This is documented in great detail under https://support.cadence.com/apex/techpubDocViewerPage?xmlName=settingup.xml&title=Setting%20Up%20Your%20Environment%20--%20Setting%20Up%20Your%20Environment%20-%201.2%C2%A0The%20cds.lib%20File&hash=SettingUpYourEnvironment-1.2cdslibThecds.libFile&c_version=18.09&path=SettingUp/SettingUp18.09/Setting_Up_Your_Environment.html#SettingUpYourEnvironment-1.2cdslibThecds.libFile please do take a look at that.
    Note that if you are using irun or xrun as your compiler front-end, you can actually avoid cds.lib and hdl.var files completely, these commands take a switch "-makelib" which allows you to define a library and send files to that library. For example:
    xrun -makelib rtllib src/rtl/*.vhd -endlib tb.sv
    The above command would compile all the files from the src/rtl directory into a library called rtllib.
  • fooyu
    fooyu over 7 years ago in reply to StephenH
    problem solved. Thanks for your support Stephen.
