  2. Functional Verification
  3. irun with illegal localparam in list of parameters [12.2...
  • Subscribers 67
  • Views 6382
irun with illegal localparam in list of parameters [12.2(IEEE-2001)].
Ncsim User 1
Ncsim User 1 over 7 years ago
Hi Cadence,
I use irun(64): 15.20-s029 to run some SV files I fetched from the internet.
I am getting this error but it seems those are correct syntax in Verilog 2001 and later.
How do I fix those?
Thank you!
file: ../tb/tnoc/rtl/bcm/tbcm_counter.sv
  localparam  int WIDTH         = $clog2(MAX_COUNT + 1)
ncvlog: *E,LOCALP (../tb/tnoc/rtl/bcm/tbcm_counter.sv,6|11): illegal localparam in list of parameters [12.2(IEEE-2001)].
 module gncorelib.tbcm_counter:sv
  errors: 1, warnings: 0
module tbcm_counter #(
  parameter   int MAX_COUNT     = 3,
  parameter   int MIN_COUNT     = 0,
  parameter   int INITIAL_COUNT = MIN_COUNT,
  parameter   bit WRAP_AROUND   = 1,
  input   logic             clk,
  input   logic             rst_n,
  input   logic             i_clear,
  input   logic             i_set,
  input   logic [WIDTH-1:0] i_set_value,
  input   logic             i_up,
  input   logic             i_down,
  output  logic [WIDTH-1:0] o_count,
  output  logic [WIDTH-1:0] o_count_next
  localparam  bit [WIDTH-1:0] INITIAL = INITIAL_COUNT;
  localparam  bit [WIDTH-1:0] MAX     = MAX_COUNT;
  localparam  bit [WIDTH-1:0] MIN     = MIN_COUNT;
  logic [WIDTH-1:0] count;
  logic [WIDTH-1:0] count_next;
  • StephenH
    StephenH over 7 years ago
    It is legal code, but unfortunately this was not supported in Incisive; you could only have localparam declarations in the module body, not the parameter port list in Incisive.
    If you can switch to using Xcelium then you won't have any problem with this code; Xcelium supports declaring localparm in the parameter port list.
    Bear in mind that Incisive stopped being developed (no new features) since 2016!
  • Ncsim User 1
    Ncsim User 1 over 7 years ago in reply to StephenH
    Thank you StephenH for the response.
    I think I am outdated on these tools. Is Xcelium going to replace irun/ncsim?
  • StephenH
    StephenH over 7 years ago in reply to Ncsim User 1
    Yes, Incisive reached the end of its life in 2016 when Xcelium was born. We do still issue bug fixes for Incisive, but we don't put new features in. Eventually Cadence will stop issuing bug fixes for Incisive, but that's not happening immediately due to some customers who are locked onto Incisive for long-term projects (mainly due to functional safety tool version requirements).
    Xcelium is based off the Incisive code base, with the addition of the RocketSim multi-core engine and has many new features compared to Incisive. For most users it's a seamless swap, Xcelium even accepts the old irun / nc* commands for backwards compatibility (though it prefers you to use xrun). The only caveat is that you need to get your Incisive licences converted to Xcelium ones, but again that should be a simple process and has the benefit that some things that used to be add-on licences in Incisive become standard in Xcelium, so you get more for your money Slight smile
