  2. Functional Verification
  3. While debugging systemverilog@incisive, how do I print ...
  • Subscribers 67
  • Views 3538
While debugging systemverilog@incisive, how do I print "this"?
Avidan
Avidan over 7 years ago
xcelium> run -step
../uvm-1.2/src/base/uvm_objection.svh:829       comp.raised(this, source_obj, description, count);
xcelium> value this
xmsim: *E,PNOOBJ: Path element could not be found: this.
Avidan
  • StephenH
    StephenH over 7 years ago +1
    "this" is not a variable which is why the debugger won't print it. If you use the "where" command it will print the class handle of the scope you're in, which is the same thing as "this".
  • StephenH
  • Avidan
    Avidan over 7 years ago in reply to StephenH
    Thanks. So say I'm stopped somewhere in a uvm_component, how do I print m_name? will this work?
    value [where].m_name
  • StephenH
    StephenH over 7 years ago in reply to Avidan
    No, just "value m_name". Just like in SV, you do not need to prefix class variables with "this" unless you are trying to disambiguate between a class variable and a function's local variable.
