  2. Functional Verification
  3. Issues in simulation without -uvmnoautocompile with uvm...
  • Subscribers 67
  • Views 3698
Issues in simulation without -uvmnoautocompile with uvm 1.2
shrac123
shrac123 over 7 years ago
  I am trying to rum my simulation without
  \-uvmnoautocompile \ and uvm 1.2
  Version : irun(64): 15.20-s030: (c) Copyright 1995-2017 Cadence Design Systems, Inc.
I am getting the error message.
ncvlog: *E,UNDIDN (/pkg/cadence-incisiv-/15.20.030/i686-linux/tools/methodology/UVM/CDNS-1.1d/additions/sv//cdns_recording.svh,79|16): 'm_handles': undeclared identifier [12.5(IEEE)].
ncvlog: *E,DLCSMD: Dependent checksum verilog_package worklib.cdns_assert2uvm_pkg:sv (VST) doesn't match with the checksum that's in the header of: verilog_package worklib.cdns_uvm_pkg:sv (VST).
irun: *E,VLGERR: An error occurred during parsing.  Review the log file for errors with the code *E and fix those identified problems to proceed.  Exiting with code (status 1).
irun: *E,UVMCXF: The process to compile the uvm extensions has failed. Add -uvmnocdnsextra to disable the addon package or point to the right version using -uvmexthome.
community.cadence.com/.../error-object-found-for-name-dut-register-but-language-domain-is-not-supported
Reading from this blog it states that cadence transaction recording is written with version 1.1d.
I dont want to revert to 1.1d since some VIP that i am using are not backward compatiable.
Is it solved or re-written in later version?
Regards.
  • StephenH
    StephenH over 7 years ago
    I'm having difficulty understanding your flow. Do you mean you are running "irun -uvmhome CDNS-1.2 -uvmnoautocompile"? Or some other set of switches?
