  2. Functional Verification
  3. Merging data base with two RTL changes
  • Subscribers 67
  • Views 15427
sgaikwad
sgaikwad over 7 years ago
Hi team,
Do we have any provision to merge two different version of coverage .icc files?
Example. I have generated coverage data base D1 with RTL changeset CL1. There are some changes done in RTL so coverage data base D2 regerated on RTL changeset CL2 . Does IMC provides any provision to merge D1 and D2?
I have tried running imc in batch mode with merge command but it is giving error.
IMC version : cadence/MDV1710
Sushant
  • StephenH
    StephenH over 7 years ago
    You would need to have instrumented coverage at elaboration time using the -covfile option, passing a control file that contains the lines:
    set_code_fine_grained_merging
    set_refinement_resilience
    Refer to this app note for details: Coverage merge failure due to design changes across tests: Causes and Solutions
