  2. Functional Verification
  3. Is there a way to adapt vRfine file after RTL source file...
  • Subscribers 67
  • Views 16162
Is there a way to adapt vRfine file after RTL source file updated and line number changed
yxpe
yxpe over 7 years ago
In case of we have a vRefine file(eg: expression exclusion), and then RTL source file is modified which result in line number changing,
when we apply vRfine file in IMC, the exlusion can not be applied correctly because previous code line changed.
Does anyone know is there a way we can use to adapt vRfine file  conveniently to avoid manual modification of vRfine file?
  • StephenH
    StephenH over 7 years ago
    Hi. Yes, you need to enable refinement resilience in the coverage control file using the command set_refinement_resilience. Please look at the documentation on support.cadence.com for full details.
  • yxpe
    yxpe over 7 years ago in reply to StephenH
    Thanks a lot, very helpful.
