  2. Functional Verification
  3. Array of covergroup not supported
  • Subscribers 67
  • Views 19238
rohith07d
rohith07d over 7 years ago
I have defined a covergroup inside a package and creating instances of it in a class as shown below:
covergroup example_cg(bit en);
  option.name = "ex_cg";
  option.per_instance = 1;
  ex_cp: coverpoint en;
endcovergroup
class ex_coverage_collector extends uvm_component;
  example_cg ex_cg[4];
endclass
I am getting this error:
xmvlog: *E,CGIANS Arrays of covergroup instances are not supported
What is the best approach to create multiple covergroup without code replication?
  • muffi
    muffi over 7 years ago
    Hi Rohith,
    The Cadence simulator does not support an array of covergroup instances. The following article documents two workarounds.
    Article (20242566) Title: Creating an array of covergroup instances
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000tdB5EAI
    I hope this helps.
