  2. Functional Verification
  3. using eManager to read regression files but failed.
  • Subscribers 67
  • Views 18199
himotor
himotor over 7 years ago
when i tried using eManager to read regression files but failed, so no data is available when click vplan button for verification plan map and code coverage analysis using IMC.
eManager's log is attached below. can anyone who had any experience on this help? thanks so much.
*** Warning: VM_UCM_FILE_READ_FAILED: Failed to read coverage model file /user/hxzh.tmp/20190513/nor_regression.hxzh.19_05_27_10_23_55_8052/testcase_model_28a5ee8a-8061-11e9-b383-bb4d3052dabc_nor_regression_default.ucm. Model skipped.
To change the severity, type:
set notify -severity=<new-severity-level> VM_UCM_FILE_READ_FAILED
To see possible severity levels use 'set notify -help'
*** Warning: VM_UCM_FILE_READ_FAILED: Failed to read coverage model file /user/hxzh.tmp/20190513/nor_regression.hxzh.19_05_27_10_23_55_8052/model_dir/icc_73072a11_5c7615b8.ucm. Model skipped.
  • StephenH
    StephenH over 7 years ago
    Hello Himotor. Enterprise Manager is a end-of-life product, and isn't supported any more, you should consider upgrading to the current vManager, which is based on the same GUI technology as IMC.
    You didn't mention which eManager or simulator versions you're using, I suspect you're using a simulator version that's too new for eManager, hence eManager can't read the coverage files.
  • himotor
    himotor over 7 years ago in reply to StephenH
    my teammates are using the same eManager and version as well, they can read the same regression files which was generated from same simulatior and its version while i cannot.  so i suspect it's not the tool version issue... any other point of view from your side, thanks so much.
  • StephenH
    StephenH over 7 years ago in reply to himotor
    Maybe it's a file permissions problem. You've really not given much information for us to go on.
  • himotor
    as mentioned above, *** Warning: VM_UCM_FILE_READ_FAILED message shows that the ucm files of regression cannot be loaded, maybe this is the cause of failure. but in the successful case, shouldn't have this warning there.
  • StephenH
    Unfortunately that message is very generic, it doesn't give enough information to diagnose the failure.
  • himotor
    thank you so much.
