  2. Functional Verification
  3. xmelab: *E,CUVDNF (./netlist.vams,1748|8): Could not determine...
  • Subscribers 67
  • Views 6614
xmelab: *E,CUVDNF (./netlist.vams,1748|8): Could not determine discipline for this expression
Abhishek Verma
Abhishek Verma over 7 years ago
Hey experts,
We are facing an error while running xrun for simulation of netlist:
<SomeModule> <SomeModuleInstance> ( .() ..........
I wanted to know what is the meaning of this violation and what might be a tentative fix. I have already made sure that this module is present in filelist.f.
Abhishek
  • StephenH
    StephenH over 7 years ago
    Really not enough information to help you here, if you cannot share more detail in public, please login to support.cadence.com and file a ticket so one of the hotline team can assist in private.
  • Abhishek Verma
    What more information do you required StephenH. I have only removed hierarchy information. Other than that is the only information I am getting from xrun. Do you might know what is the intention of this violation?
  • TAM1
    TAM1 over 7 years ago in reply to Abhishek Verma
    I've seen that message when I was connecting an analog signal to a digital port. In a mixed signal simulation, there are auxiliary files that I needed to add that described a "discipline" that indicated how analog values were to be interpreted as digital ones and vice versa.  As Stephen said, we don't know enough about what you are modeling to say what you might be needing.
