  2. Functional Verification
  3. Viewing Classes in Simvision
  • Subscribers 68
  • Views 19861
DylanC
DylanC over 7 years ago
Hello all,
I've just started creating a more robust test bench structure using classes.  I've never tried to use classes in verification before and so I'm having some trouble understanding how to view them in Simvision.
I've created a simple testbench with various classes for running the tests.  I can see the classes in Simvision waveform window but there is no data for them.  I do have data for the DUT signals and the testbench seems to be working correctly.
Is there something I need to do to make sure the data for classes is recorded?  I'm using the $shm_probe to create the database but I don't see a switch for collecting class data.
Thank you for any assistance.  I'm pretty new to Simvision so I'm probably missing a lot.
Dylan
  • Tudor Timi
    Tudor Timi over 7 years ago +1
    Add '-dynamic' to your 'probe' command. I typically have 'probe -create -all -depth all -dynamic'. Side node: I don't know what '$shm_probe' does, but it seems like it's connected to probing. You can…
  • StephenH
    StephenH over 7 years ago +1
    As Tudor says, you need to probe the dynamic objects; this cannot be done from the $shm_probe system task, you need to use the Tcl commands. In general we don't recommend using the system tasks as they…
  • Tudor Timi
    Side node: I don't know what '$shm_probe' does, but it seems like it's connected to probing. You can replace this system task call with simulator TCL commands. Look for 'database' and 'probe' in 'cdnshelp'.
  • StephenH
    As Tudor says, you need to probe the dynamic objects; this cannot be done from the $shm_probe system task, you need to use the Tcl commands. In general we don't recommend using the system tasks as they aren't very flexible and lead to bad habits like always dumping waves even for regression runs.
  • DylanC
    DylanC over 7 years ago in reply to Tudor Timi
    Ah, ok.  I will have to change to using the probe command instead of the system task($shm_probe).  Thank you for the clarification.
  • DylanC
    DylanC over 7 years ago in reply to StephenH
    I suspected the $smh_probe was probably not going to work.  I'm working on an existing design and they used $shm_probe so I didn't want to change it unless knew it was the problem.  Thank you for the info.  I'll have to change to using the probe command instead of system tasks.
