  2. Functional Verification
  3. Reading an input file using std.textio
  • Subscribers 67
  • Views 18280
rafaelkl
rafaelkl over 7 years ago
I 'm having a problem trying to read an input file on a testbench on Incisive.
I believe the problem is due to a wrong file path, but I tried to copy the file to several folder and none worked.
The line I'm using, which worked in other simulator is:
    file input_file: text is in "test_in.txt";
On Irun command, I obtain the error:
    ncvhdl_p: *E,ILLPRI (../tb/tb_top.vhd, 112|35): expecting an expression or operand [7.1] [7.3].
Any idea what could be the problem?
Thank you!
  • TAM1
    TAM1 over 7 years ago in reply to rafaelkl +1
    This compiles without complaint with the -v93 option. It is the extra keyword "in" that is required by the '87 standard and appears in your original example that leads to the ILLPRI error.
  • StephenH
    StephenH over 7 years ago
    The problem isn't anything to do with where your stimulus file is on disk, the error is coming from the parser, indicating something is wrong with your source code. I can't see anything obviously wrong with your code, so it might be dependent on something from a line above this one. Can you reproduce this in some trivial example, or at least show us what's on the preceding lines?
  • TAM1
    The syntax for declaring an input file changed between the '87 and '93 versions of VHDL. If you are using -v93 or -v200x you can declare your file like:
        file input_file: text is "test_in.txt";
  • rafaelkl
    Sorry, I should have posted more of the code.
    I'm using basically this:
    process
        FILE vector_file_in: text IS "test_in.txt";
        VARIABLE input_line : line;
        VARIABLE str_stimulus_in: string(8 DOWNTO 1);
    begin
    WHILE NOT endfile(vector_file_in) LOOP
         readline(vector_file_in, input_line);
        read(input_line, str_stimulus_in);
    -- tests
    end loop;
    end process;
    I am using -v93, so may be this the problem. But Modelsim is also configured to use it and works fine.
    Unfortunately I can only test next week.
    Thanks!
  • TAM1
  • rafaelkl
    rafaelkl over 7 years ago in reply to TAM1
    That worked. Just had to remove the "in" keyword. Thank you!
