  2. Functional Verification
  3. vManager tool gives this error-"Error:Project Environment...
  • Subscribers 67
  • Views 4098
vManager tool gives this error-"Error:Project Environment Selection is required by server,and must be set on this mode"
rahul97
rahul97 over 7 years ago
Hi all..
I need to generate the regression report (of selected sessions) in the form of csv file in cadence vManager tool using batch mode commands. The command I used is -
"vmanager -exec  cmnd", where cmnd is a file containing the command ' csv_export -sessions -view All_Sessions -filter "start_time:> 6/17/19 10:49 PM" -out regr.csv '
But I have been getting the following error-
Can anyone let me how to resolve this?
  • StephenH
    StephenH over 7 years ago
    Try "setenv VMGR_PROJECT foo", replacing "foo" with the project name that you want to connect to on the server.
  • DerekG0
    DerekG0 over 7 years ago in reply to StephenH
    I'm surprised there isn't a command line option for this. And there's nothing in the documentation.
    Do you know how to specify the password? Using that environment variable, I now get this error:
    Error: Login details are required by server. For execution mode, the corresponding environment variables must be set
    And doesn't tell you what environment variables :( But I don't want to set the password via an env var anyway.
    Many thanks.
  • DerekG0
    DerekG0 over 7 years ago in reply to DerekG0
    My mistake, I did find that env var in the documentation, but of course you need to know it exists! I found it in:
    19.05 / Installation / Cadence vManager Installation and Configuration Guide / Appendix E: Environment Variables
    There you'll see that you can use VMGR_PASSWORD to set the password, however, I would consider that insecure. See this article for different command line invocations of vmanager to get it to prompt you for a password. I found it didn't prompt me because I had already save my credentials from an earlier run of vmanager. I think the token based method is the way to go for true batch mode.
