  2. Functional Verification
  3. Verifying Configurable RTL with JasperGold
  • Subscribers 67
  • Views 18845
Andrew R
Andrew R over 7 years ago
Currently I am trying to verify an RTL file which is created with Parameters and Generate statements. This module is made this way so that I can be used multiple projects and adapt to the parameters that it is passed from the top level. I wanted to know if the JasperGold platform has any way to verify the module with various parameters automatically, or If I manually have to set these parameters and then verify.
Thank you.
  • TAM1
    TAM1 over 7 years ago +1
    Jasper will test all legal values for data, such as values on ports or registers. So if you are using parameters to configure your design's internal data, that will be tested. But Jasper doesn't dynamically…
  • TAM1
    Jasper will test all legal values for data, such as values on ports or registers. So if you are using parameters to configure your design's internal data, that will be tested. But Jasper doesn't dynamically change the underlying hardware itself. That is a fixed foundation on which the data moves.
    You'll need to make individual runs, each with a different hardware configuration you want to test. You can specify different TCL scripts with various settings on the analyze and elaborate commands. Or you can create different top level wrapper modules which instantiate the variations you want to test.
    Many hardware configuration possibilities don't need to be individually tested. For example, various bit widths of a data path are usually considered equivalent. You may want to make tests when the width crosses a word or byte boundary. But Jasper users don't commonly run 64 separate tests for their data path.
