  2. Functional Verification
  3. Issue with merging code coverage with different parameter...
  • Subscribers 67
  • Views 17620
Issue with merging code coverage with different parameter values written inside generate block
Btarpara
Btarpara over 7 years ago
I've ran couple of tests for below RTL code. One with parameter COUNTER value 1 and another test with COUNTER value 0.
Now, I could not merge the coverage for both tests cases.
Command used for merging : merge cov_work/scope/* cov_work/scope_0/* -out all (in imc -batch)
Warning message : *W,WEMMO1: Module/Generate/NamedBlock 'generate_check.genblk1_T' not merged because it is not present in target run.
*W,WEMIN1: Instance 'gen_tb.DUT.genblk1' and its hierarchy not merged with target instance 'gen_tb.DUT.genblk1' and its hierarchy - Mismatch in type names - Primary: worklib.generate_check.genblk1_F Secondary: worklib.generate_check.genblk1_T.
Total items not merged                      : 2
module generate_counter(clock, reset, count);
  input clock, reset ;
  output reg[3:0] count ;
  parameter COUNTER = 0;
  generate
    if (COUNTER == 1) begin
      always@(posedge clock) begin
      if (reset)
        count <= 4'b0;
      else
        count <= count +1;
      end
    end
    else begin
      if (reset)
        count <= 4'b0;
      else
        count <= count +2;
      end
    end
  endgenerate
endmodule
Is there any way in imc to merge the coverage with both parameter values ?
Can someone please help me how to merge the coverage in such cases.
Thanks.
  • StephenH
    StephenH over 7 years ago
    As far as I'm aware there is no way to merge code coverage for different specialisations of a module.
