  2. Functional Verification
  3. Macro in `include compiler directive.
  • Subscribers 68
  • Views 26319
VerificationMike
VerificationMike over 7 years ago
Hi there, SystemVerilog community,
I would like to run several instances of a simulation, each with a separate include file rom a different path. I would like to hand a +define+FILEPATH to the simulation and use the in the line, where I include the files. Now, what I have found out is, that an "include" directive cannot resolve macros. Is that correct? Is there a way around it? Do you have any suggestions?
Example with code:
call simulation with +define+FILEPATH "/.../..."
then use:
`include FILEPATH
-> can't be done.
Thank you for any help on this.
Michael
  • muffi
    muffi over 7 years ago +1
    Hi, The following works: > more test.sv `define FILEPATH "" //`include "foo.sv" `include `FILEPATH module test; foo foo_i(); initial begin $display("module test"); $display("FILEPATH = %s", `FILEPATH);…
  • StephenH
    StephenH over 7 years ago
    You really don't want to use a macro for this, as it would force you to recompile for each simulation. You should consider using the $value$plusarg() call to pass in a string at simulation time:
    xrun -R +rom_file=/path/to/rom_image.hex
    string romfile;
    initial begin
      if ($value$plusargs("rom_file=",romfile))
        $readmemh(....);
      else
        $fatal(1,"No ROM file specified");
    end
  • Tudor Timi
    Tudor Timi over 7 years ago
    Haven't tried it out myself, but if you would want FILEPATH to be dereferenced as a define, you should write:  `include `FILEPATH
    Still not sure if this will work
  • Tudor Timi
    Tudor Timi over 7 years ago in reply to StephenH
    I think the op wanted to say "each file from a different path" and was not talking about preloading a ROM image.
  • StephenH
    StephenH over 7 years ago in reply to Tudor Timi
    Good point Tudor, clearly I need more coffee ;-)
  • muffi
     > more test.sv
    `define FILEPATH ""
    //`include "foo.sv"
    `include  `FILEPATH
    module test;
      foo foo_i();
      initial begin
      end
    endmodule
    > more foo.sv
    module foo;
      initial $display("module foo");
    endmodule
    > xrun -clean test.sv +define+FILEPATH='"foo.sv"'
    Log Snippet:
    xcelium> run
    module foo
    module test
    FILEPATH = foo.sv
    xmsim: *W,RNQUIE: Simulation is complete.
    xcelium> exit
  • VerificationMike
    Hi everybody, thank you for your very quick help!
    I confirm muffi's code works for me, too.
    I made an interesting observation, though. I tried a similar line, that didn't work, which is why I came to this forum, in first place.
    What I literally had in my code was something like this:
    `include "/../../.."`FILEPATH"/../.."
    So, I actually just wanted to hand various directory names per external defines to the simulator. And this apparently cannot be done! So, macros, that would need to replaced inline, can't be resolved. Full paths given per macro, like in muffi's example work, though.
    I just wanted to share this with you. muffi's solution solves my issue, as I can hand over full paths in my flow.
    Again, thank you all!
    Michael
