  2. Functional Verification
  3. VPlan Report- links for each test
  • Subscribers 67
  • Views 1865
mxm1489
mxm1489 over 7 years ago
Hi all,
I would like to generate a vplan report in order to have an html link for each entity of the plan.so people that want to check if the requirment has been covered can click on the link and see the results relatives to that req..Do you know if it is possible?
Max
  • StephenH
    StephenH over 7 years ago
    I don't understand the request - each section in the vPlan should correlate to a requirement, thus you would see directly if the coverage of that section is complete or not. Are you asking for a way to correlate external requirements (from some other database) with the ad-hoc verification plan? If so, you can do this by creating a list of the requirements and linking the relevant vPlan sections to those requirements. We have some guidelines for this on the main support.cadence.com portal, as part of the automotive (ISO26262) requirements management flow.
