  2. Functional Verification
  3. Export a Breakpoint
  • Subscribers 67
  • Views 17219
Export a Breakpoint
Elnic8745
Elnic8745 over 7 years ago
Hi all,
I was running a simulation with Xcelium in Simvision and I save few breakpoints.
I would like now to run another simulation (so from a different console) and loading one of the breakpoints of another simulation
Is this possible?
I try with the File -> Save Command Script and then sourcing the restore file but it is taking a lot of time
  • Doug Koslow
    Doug Koslow over 7 years ago
    You could just extract the appropriate stop command(s) from the xrun.key or xmsim.key file into a new file and source that.
    - Doug
  • Elnic8745
    Elnic8745 over 7 years ago in reply to Doug Koslow
    Hi Doug, thanks for your answer. Unfortunately inside my xrun.key there is nothing that I guess can be considered useful for exporting the breakpoint.
  • Doug Koslow
    Doug Koslow over 7 years ago in reply to Elnic8745
    If you set a breakpoint, a stop command should be in the .key file. If not, I suggest filing a support ticket on the issue.
    Thanks.
    - Doug
