  2. Functional Verification
  3. Design library not defined while reading module with nc...
  • Subscribers 67
  • Views 23863
Design library not defined while reading module with ncsim
cuonghl
cuonghl over 7 years ago
Hi supporters,
I got the following error while I run simulation with gate netlist using Cadence Incisive (v15.20):
ncsim(64): 15.20-s076: (c) Copyright 1995-2019 Cadence Design Systems, Inc.
ncsim: *E,DLOALB: Design library 'tcbnxxx' not defined while reading module tcbnxxx.MAOxxx:bv (VST).
ncsim: *F,NOSIMU: Errors initializing simulation 'alu_tb'
xxx: standard library name.
My netlist design uses a cell "MAOxxx". I already included the library behavior model to compile using ncverilog, there is no error while compiling. But when I run with ncsim to execute the test, I got above error.
I tried to run with other vendors such as VCS or MTI, they worked.
Please help to understand the error.
Thanks.
  • StephenH
    StephenH over 7 years ago
    It looks like you are using a legacy workflow with Incisive, where you defined a cds.lib and hdl.var file, and invoked the ncvlog, ncelab and ncsim directly. The error message comes because the compiled design refers to a Verilog (or VHDL) library name that wasn't listed in your cds.lib file. I would guess that you used a valid cds.lib when compiling the design but that you're simulating in a different directory where you either have no cds.lib, or the wrong cds.lib.
  • cuonghl
    cuonghl over 7 years ago in reply to StephenH
    Actually, I don't touch the cds.lib. Here is the follow that I used (it worked when I run simulation using RTL):
    - Compile: ncverilog -64bit -clean -elaborate -access +wr -uvm -uvmhome $(UVM_HOME) -sv +nccoverage+A +nccov_cgsample +nctimescale+1ns/1ns -f $(LIST)
    - Simulation: ncsim -64bit -covoverwrite -sv_lib $(DPI_LIB) -svseed $(SEED) -log simulate.log $(TOP) +UVM_TESTNAME=$(TEST)
    It happened when I retried to bring up GLS, the netlist use some library macro model.
    Maybe I missed something, can you help guide me?
    Here is the content of "INCA_libs/irun.lnx8664.15.20.nc/cds.lib":
    1 include ./cdsrun.lib
    2 include ./xllibs/cds.lib
    Then I checked the "xlibs/cds.lib" and I saw the library definition:
    define tcbnxxx ./tcbnxxx
    Thanks.
  • StephenH
    StephenH over 7 years ago in reply to cuonghl
    Thanks for the clarification. So, the cds.lib does look ok, which leads to the question, did you compile anything into your tcbnxxx library? Does the ./tcbnxxx directory even exist? You could check by doing the command "ncls -library tcbxxx"; it should list all the compiled Verilog objects from the library, so if it reports nothing, or if it reports that it can't find the library, that is your problem.
  • cuonghl
    I found that library was compiled OK. However the "ncsim" command couldn't load the "cds.lib" and "hdl.var", that's why the error happened.
    When I provide the options in "ncsim" command to specify the cds.lib and hdl.var. It works.
    ncsim -cdslib INCA_libs/snap.nc/cds.lib -hdlvar INCA_libs/snap.nc/hdl.var -64bit -covoverwrite -sv_lib $(DPI_LIB) -svseed $(SEED) -log simulate.log $(TOP) +UVM_TESTNAME=$(TEST)
    I'm not sure why ncsim could not load cds.lib and hdl.var automatically?
