  2. Functional Verification
  3. Simvision Schematic Information
  • Subscribers 66
  • Views 16768
Elnic8745
Elnic8745 over 6 years ago
Hi all,
I would like to understand if it is possible from Simvision to get the information regarding the view of a block. In principle using the Schematic Tracer Simvision is able to find the information about the config of that particular model, but I did not found a command for describing the nature of the module (for example if it is schematic or rtl or real model...)
Any functions that I can use for this purpose?
Many thanks
  • StephenH
    StephenH over 6 years ago
    Why not simply send the selected block from the schematic to the source browsers? Then you'd see the source code and it would be clear what type of model it is.
