  2. Functional Verification
  3. IMC : fsm coding style not auto extracted/Identified by...
  • Subscribers 67
  • Views 2503
IMC : fsm coding style not auto extracted/Identified by IMC
garika
garika over 6 years ago
I've vhdl block containing fsm . IMC not able to auto extract the state machine coded like this:
There is a intermediate state state_mux  between next_state & state.
Pls. help in guiding IMC how to recognize this FSM coding style?
Snipped of the fsm code:
               type state_type is (ST_IDLE, ST_ADDRESS, ST_ACK_ADDRESS, ST_READ, ST_ACK_READ, ST_WRITE, ST_ACK_WRITE, ST_IDLE_BYTE);
               signal state : state_type;
               signal state_mux : state_type;
               signal next_state : state_type;
process(state_mux, start)
         begin
               next_state <= state_mux;
               next_count <= (others => '0');
           case (state_mux) is
                 when ST_IDLE =>
                            if(start = '1') then
                                 next_state <= ST_ADDRESS;
                              end if;
            when ST_ADDRESS =>
          when others => null;
         end case;
     end process;
process(scl_clk_n, active_rstn)
               begin
                      if(active_rstn = '0') then
                           state <= ST_IDLE after delay_f;
                  elsif(scl_clk_n'event and scl_clk_n = '1') then
                             state <= next_state after delay_f;
                            end if;
end process;
process(state, start)
               begin
                     state_mux <= state;
                       state_mux <= ST_IDLE;
                              end if;
               end process;
Raghu
  • StephenH
    StephenH over 6 years ago
    You can't "educate" IMC to recognise other coding styles, so you'll need to follow one of the standard FSM styles as documented here: Modeling Styles Supported
