  2. Functional Verification
  3. Can't collect AXI4 burst_started coverage
  • Subscribers 67
  • Views 1667
kkurenkov
kkurenkov over 6 years ago
I have a problem connected with my AXI4 coverage.
I enable coverage collection in AXI4
      set_config_int("axi4_active_slave_agent_0.monitor.coverModel", "burst_started_enable", 1);
      set_config_int("axi4_active_slave_agent_0.monitor.coverModel", "coverageEnable", 1);
but i don't have a result.
I think the problem in Callback, but i try to connect all callback and i don't have positive result.
Can you help me?
  • StephenH
    StephenH over 6 years ago
    Have you looked at the AXI: How to Enable Coverage Collection andWhat are CDN AXI coverage level settings articles on support.cadence.com?
    I beleive you would only require teh callbacks if you want to add your own coverage on top of the built-in covergroups. If that's what you're looking to do, the following atricle may also be of help: https://support.cadence.com/apex/articleattachmentportal?id=a1Od0000002JevNEAS&pageName=ArticleContent&attachId=069d0000001JLcGAAW
