  2. Functional Verification
  3. How to run a regressive test and merge the ncsim.trn file...
  • Subscribers 67
  • Views 17261
How to run a regressive test and merge the ncsim.trn file of all test into a single file to view the waveform in simvision ?
sriganeshd
sriganeshd over 6 years ago
Hi all,
         I want to know how to run a regressive test in cadence and merge all ncsim .trn file of each test case into a single file to view all waveform in simvision. I am using Makefile to invoke the test case.
         eg:-
               test0:
                     irun -uvm -sv -access +rwc $(RTL) $(INTER) $(PKG) $(TOP) $(probe) +UVM_VERBOSITY=UVM_MEDIUM +UVM_TESTNAME=test0
             test1:
                   irun -uvm -sv -access +rwc $(RTL) $(INTER) $(PKG) $(TOP) $(probe) +UVM_VERBOSITY=UVM_MEDIUM +UVM_TESTNAME=test1
          I just to call test0 followed by test1 or parallel both test and view the waveform for both tests case.
        I new to this tool and help me with it
  • StephenH
    StephenH over 6 years ago
    I don't understand why you would want to do this; normally tests are easier to debug if you keep them short and simple, why would you want to combine them all into a single waveform file? What would it even mean to merge them?
  • sriganeshd
    sriganeshd over 6 years ago in reply to StephenH
    Hi StephenH
                 Thanks for your reply.  I just wanna run a regressive test.  I have done this in my old company with another tool.  I don't know how to do this in cadence.  I am doing the regressive test for coverage. when I call two tests continuously the coverage file in cov_work is getting overwritten.  I want to merge all coverage file for each test to make it a single file, i could get more coverage.
    waveform is not required,  just coverage.
