  2. Functional Verification
  3. Info regarding released version Cadence IES simulator
  • Subscribers 67
  • Views 10121
FormerMember
FormerMember over 6 years ago
Hello folks,
Greetings.
One of my customer claims that he is using Cadence IES version 18.09.011 with Vivado 2019.2. The version of IES that we officially support with Vivado 2019.2 is 15.20.073. Though the tool is forward compatible, I am not sure what are the versions of IES that are released after 15.20.073. Could you please give me a list of the versions of Cadence IES released after 15.20.073 and which is the latest version as of now ?
Best regards,
Chinmay
  • StephenH
    StephenH over 6 years ago +1
    Hi Chinmay. To be precise, Incisive ceased at 15.20, thereafter it was replaced by a product named Xcelium. The latest Xcelium version is 19.09, each major release comes out at 6 month intervals, so…
  • StephenH
    StephenH over 6 years ago in reply to FormerMember +1
    Yes, that's very likely. Note that Cadence only supports (provides bug fixes) for 12 months for each major release, after that customers arr required to upgrade to a newer release to get bug fixes. Hence…
  • StephenH
    Hi Chinmay.
    To be precise, Incisive ceased at 15.20, thereafter it was replaced by a product named Xcelium. The latest Xcelium version is 19.09, each major release comes out at 6 month intervals, so the next will be 20.03 in March.
  • FormerMember
    FormerMember over 6 years ago in reply to StephenH
    Thanks for the quick response Stephen. I suspected that too. I think he is using Xcelium 18.09.011.
  • StephenH
    Yes, that's very likely. Note that Cadence only supports (provides bug fixes) for 12 months for each major release, after that customers arr required to upgrade to a newer release to get bug fixes. Hence 18.09 is no longer supported.
  • FormerMember
    got it. Slight smile
