  2. Functional Verification
  3. How to refer the library compiled by INCISIVE 13.20 in Xcelium...
  • Subscribers 66
  • Views 19193
How to refer the library compiled by INCISIVE 13.20 in Xcelium 19.30
mrselee
mrselee over 6 years ago
I am facing this elaboration error when using Xcelium:
Command>
    xmverilog -v200x +access+r +xm64bit -f vlist -reflib plib -timescale 1ns/1ps
Log>
    xmelab: *E,CUVMUR (<name>.v,538|18): instance 'LUTP0.C GLAT3' of design unit 'tlatntscad12' is unresolved in 'worklib.LUTP0:v'.
I guess the plib was not referred to as the simulation configuration because the tlatntscad12 is included in plib.
The plib is compiled by INCISIVE 13.20 and I am using the Xcelium 19.30.
Please tell me the correct command on how to refer to the library directory compiled by different versions.
Thank you,
  • StephenH
    StephenH over 6 years ago
    You must compile everything including the plib with the same tool version, you cannot mix and match different tool versions.
  • mrselee
    mrselee over 6 years ago in reply to StephenH
    Stephen, thank you for your response.
