  2. Functional Verification
  3. search for glob/regexp in specman loaded modules?
  • Subscribers 67
  • Views 4014
aefody
aefody over 6 years ago
Specman *search* command allows searching in all loaded modules, but only for a string.
Is there a way to search for a regexp or glob?
Alternatively, is there a way to simply get a list of all loaded files somehow? Then I could use either the "shell" command, or real shell together with grep.
  • StephenH
    StephenH over 6 years ago +1
    If you open the Specman GUI ("specview" in stand-alone mode, or as part of SimVision if used with Xcelium), then there are options to search in a multitude of different ways including regexps, globs, looking…
  • StephenH
    If you open the Specman GUI ("specview" in stand-alone mode, or as part of SimVision if used with Xcelium), then there are options to search in a multitude of different ways including regexps, globs, looking only in specific eVCs, etc.
    In batch mode you can do "show modules" to list the loaded files.
  • aefody
    aefody over 6 years ago in reply to StephenH
    errr...that window just went busy on me for 10 minutes and still counting. Show modules in batch mode + normal grep that you can ^C would be a better option.
