  2. Functional Verification
  3. XmVlog - *F,DIRDEC error
  • Subscribers 67
  • Views 9516
yavuzselim
yavuzselim over 6 years ago
I'm trying to compile a simple verilog file using xmvlog. I run the following command,
"xmvlog myfile.v"
Then I get the following error,
"xmvlog: *F,DIRDEC: Can't save decompressed versions of compressed files."
I used to use xmvlog with no issues, this error started to come up now. The message is not helpful either. How can I solve this?
I appreciate any help, thanks in advance.
  • muffi
    muffi over 6 years ago
    The extended help for this error says:
    $ xmhelp xmvlog dirdec
    xmhelp: 19.03-s019: (c) Copyright 1995-2020 Cadence Design Systems, Inc.
    xmvlog/dirdec =
        There is no room/permission to keep the decompressed versions of compressed files. Try cleaning the /tmp directory.
    It looks like Xcelium is using the /tmp directory when it needs to decompress a local file. It may be that, although your working directory has plenty of space, your LSF farm machines may have smaller or full /tmp disks.
    Here is an article that shows how to use an environment variable to direct Xcelium to use a different directory for its uncompressed files.
    Article (20472355) Title: How to direct the simulation toolset to use a particular disk area for temporary files
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006AjQuUAK
    I hope this helps.
