  2. Functional Verification
  3. VManager : Increase and Decrease the number of parallel...
  • Replies 7
  • Subscribers 68
  • Views 22514
VManager : Increase and Decrease the number of parallel runs in the on-going running sessions.
sumg
sumg over 6 years ago
While firing a regression that might span multiple working days, We need to increase and decrease the number of parallel runs to distribute license usages.
During working day hours, we would like to reduce the number of parallel runs and during nightly hours we should increase the parallel run.
  • Hoa Lu
    Hoa Lu over 6 years ago in reply to sumg +1
    Each session in vManager has a property "MAX RUNS IN PARALLEL" which limits number of parallel runs. You can change this property by right click on the session, select "Edit each". Besides vManager client…
  • StephenH
    StephenH over 6 years ago
    vManager cannot do this dynamically, it's a task that is typically handled by the compute infrastructure like LSF.
  • Hoa Lu
    Through vAPI, the "max_runs_in_parallel" property of a running session can be modified. Schedule a script at a specific time you want to change
  • sumg
    sumg over 6 years ago in reply to Hoa Lu
    Thanks, Hoa Lu. Can you kindly elaborate?
  • Hoa Lu
    Besides vManager client (GUI), user can interact with vManager via vAPI, scripting interface. So you can make a script to modify that field at day/night time. Your local AE may give some examples
  • sumg
    Thank Hao Lu, I will take further Help from local AE.
    Kindly confirm if both the GUI and vAPI method can be used to change the variable multiple times  "MAX RUNS IN PARALLEL" in a running session.
  • sumg
    sumg over 6 years ago in reply to StephenH
    Hi Stephen,
    Can you share your views on Hoa Lu's comments below?
  • StephenH
    StephenH over 6 years ago in reply to sumg
    So far as I'm aware, modifying the tool's configuration doesn't impact any existing running sessions, nor does it override the explicit setting in a given VSIF, the tool's configuration is just a default to be used in lieu of anything being specified in the VSIF.
