  2. Functional Verification
  3. e code coverage
  • Subscribers 67
  • Views 16745
e code coverage
aefody
aefody over 6 years ago
Is there some support for getting code coverage of my e files? I'm working in an environment where I suspect a lot of dead-code.
Avidan
  • StephenH
    StephenH over 6 years ago +1
    Hi Avidan. You can enable "block" coverage for Specman code: https://support.cadence.com/apex/techpubDocViewerPage?xmlName=sn_cref.xml&title=Specman%20Command%20Reference%20--%20Table%20of%20Contents…
  • StephenH
    Hi Avidan.
    You can enable "block" coverage for Specman code: https://support.cadence.com/apex/techpubDocViewerPage?xmlName=sn_cref.xml&title=Specman%20Command%20Reference%20--%20Table%20of%20Contents%20-%20&hash=&c_version=20.03&path=sn_cref/sn_cref20.03/sn_crefTOC.html
    config cover -block_coverage_mode=on;
    You need to issue that command before loading your e files.
  • aefody
    aefody over 6 years ago in reply to StephenH
    Just what I needed. Thanks
