  2. Functional Verification
  3. Instantiate SystemC module in SystemVerilog module with...
  • Subscribers 67
  • Views 5234
Instantiate SystemC module in SystemVerilog module with real/double ports
coderoo
coderoo over 6 years ago
I would like to instantiate a SystemC module inside a SystemVerilog module with real/double ports.
Here is some source code:
// file model.h:
#include "systemc.h"
class model : public sc_module {
public:
sc_in <double> inval;
sc_out<double> outval;
SC_CTOR(model) : inval("inval"), outval("outval") {
SC_METHOD(run);
sensitive << inval;
void run() {
outval.write(inval.read());
// file model.cpp:
#include "model.h"
XMSC_MODULE_EXPORT(model)
// file model.sv:
module model (inval, outval )
(* integer foreign = "SystemC";
input var real inval;
output var real outval;
endmodule
// top.sv:
module top;
real inval;
real outval;
initial begin
inval = 2'b0;
#10 inval = 1.0;
#10 inval = 2.0;
#10 $finish;
end
model test (inval, outval);
endmodule
Here is the command to compile and run:
xrun -sysv top.sv model.sv -sysc model.cpp -top top
I get an error:
xmelab: *F,SCVREG (./model.sv,17|21): Found a Verilog output register in the shell 'model'.
If I change the port types to [1:0]/sc_uint<2>, everything works.
How can I connect real/double ports without having to resort to $realtobits, etc.
Thank you.
