  2. Functional Verification
  3. Xcelium: Altering return value of $temperature in digital...
  • Subscribers 67
  • Views 17533
Xcelium: Altering return value of $temperature in digital simulation
MartinJ
MartinJ over 6 years ago
We would like to use the $temperature function in a SystemVerilog behavioral model in digital simulaion using Xcelium.
By default the $temperature function returns 300.15 degree Kelvin in digital simulation
Is there a possibility to change the temperature returned by that function (e.g. xrun parameter, TCL command, force ...)?
best regards
Martin
  • StephenH
    StephenH over 6 years ago
    I would assume you need the $cds_set_temperature() function: https://support.cadence.com/apex/techpubDocViewerPage?xmlName=verilogamsref.xml&title=Cadence+Verilog-AMS+Language+Reference+--+Simulator+Functions+-+Changing+the+Global+Circuit+Temperature&hash=pgfId-1174169&c_version=20.03&path=verilogamsref%2Fverilogamsref20.03%2Fchap9.html#pgfId-1174169
  • MartinJ
    MartinJ over 6 years ago in reply to StephenH
    Thanks for your reply. It seems that this function has been added in (latest) Xcelium version 20.03. Unfortunately we are using an older version (18.09) in our design environment and there function does not exist. So I will look for a solution w/o $temperature function like a signal in a global package.
