  2. Functional Verification
  3. VManager + DRM user specific config (HTCondor)
  • Subscribers 67
  • Views 20516
BGarcia
BGarcia over 6 years ago
Hello Everyone,
I am in the process of setting up a VManager + HTC server farm (using HTCondor) for regressions.
As HTCondor is not natively supported by Cadence like NC or SGE is, I need to specify it is a USER SPECIFIC DRM and then select a path of the DRM TCL implementation file.
I am unsure what this DRM TCL file contents and structure should be and I cannot find anything related to this particular file in the documentation.
Has anyone implemented anything like this and can provide me with some examples/guidelines on how to make this file?
Best Regards,
Baudilio Garcia
  • StephenH
    StephenH over 6 years ago +1
    Please refer to the section "Creating User-defined DRM API for Parallel Merge / Parallel Rank/ DRM Options " in the docs: support.cadence.com/.../techpubDocViewerPage You basically have to provide a…
  • BGarcia
    BGarcia over 6 years ago in reply to StephenH +1
    Hello Stephen, That is exactly what I was looking for! Thank you very much for your help and support!! Best Regards, Baudilio Garcia
  • BGarcia
    BGarcia over 6 years ago +1
    Hello Everyone, Sorry for comming back to this, but I have another question: I am having issues builinng the submit_job procedure specified in the documentation. I am unsure where the job_template…
  • StephenH
    Please refer to the section "Creating User-defined DRM API for Parallel Merge / Parallel Rank/ DRM Options" in the docs: support.cadence.com/.../techpubDocViewerPage
    You basically have to provide a Tcl file that implements some call-backs to submit / kill / monitor the jobs by calling out to the right commands in your DRM (HTCondor) and returning the information in the format that vManager expects.
  • BGarcia
    Hello Stephen,
    Best Regards,
    Baudilio Garcia
  • BGarcia
    Hello Everyone,
    I am having issues builinng the submit_job procedure specified in the documentation. I am unsure where the job_template parameter is created.
    Should I create the associative array on the TCL file? is this taken from the .vsif file? does this come from vManager somehow?
    Thank you for your help and support.
    Best Regards,
    Baudilio Garcia
  • StephenH
    StephenH over 6 years ago in reply to BGarcia
    Hi Baudilio.
    The job_template is given to your Tcl proc as an input from vManager, you don't have to construct it yourself. It's basically just an associative array containing a "command" key/value pair and a set of optional key/value pairs for other things that vManager might pass to you if it needs to. You Tcl has to check for these key/value pairs and decode them to control the underlying DRM submission command. There is an small example here: https://support.cadence.com/apex/techpubDocViewerPage?xmlName=vmanagerinstall.xml&title=Cadence%20vManager%20Installation%20and%20Configuration%20Guide%20--%20Setting%20Up%20the%20Regression%20Environment%20-%203.11.1.3%20submit_job&hash=SettingUptheRegressionEnvironment-3.11.1.31135112submit_job&c_version=20.03&path=vManagerinstall/vManagerinstall20.03/Setting_Up_the_Regression_Environment.html#SettingUptheRegressionEnvironment-3.11.1.31135112submit_job
  • BGarcia
    Hi Stephen,
    Thank you very much for your help so far!
    I am currently having an issue with the get_job_status procedure: TCL error when evaluating user DRM tcl file /home/baudilio.garcia/vmanager/HTCondor.tcl while calling get_job_status
    wrong # args: should be "get_job_status job_id"
    But according to the documentation, there should only be 1 argument?
    This is the procedure that I have created:
    Any ideas of what could be happening?
    Thank you very much for your help and support.
    Best Regards,
    Baudilio Garcia
  • StephenH
    Hmmm... I honestly don't know about that. You could try the Tcl "variable args list" approach as described in the Tcl docs: http://tcl.tk/man/tcl8.4/TclCmd/proc.htm so instead of "proc get_job_status {job_id}" you would do "proc get_job_status args", then treat args as an array and pick item 0 from the array inside your proc's body. If that fails, May I request you to open a support ticket on https://support.cadence.com/ so that one of the hotline team could assist you (I won't be available for a couple of weeks, and this forum isn't staffed as a full-time support channel).
