  2. Functional Verification
  3. xmvlog: *E,NOPBIND (../src/soc_tb_top.sv,46|20): Package...
  • Subscribers 67
  • Views 15701
xmvlog: *E,NOPBIND (../src/soc_tb_top.sv,46|20): Package soc_test_pkg could not be bound.
vujaclyn
vujaclyn over 6 years ago
file: soc_tb_top.sv
`include "soc_if.sv"
module soc_tb_top;
  import uvm_pkg::*;
  import soc_test_pkg::*;
endmodule
Here is my Makefile:
 xrun -uvmhome $(UVM_LIB_PATH) -uvm -64BIT +incdir+../src +incdir+../sim +incdir+../tests ../src/soc_tb_top.sv -seed $(SEED) -access +rwc ../src/soc_tb_top.sv
Here is my soc_test_pkg.sv
package soc_test_pkg;
  import uvm_pkg::*;
  import soc_env_pkg::*;
  `include "uvm_macros.svh"
  `include "soc_base_test.sv"
endpackage
This compilation error shouldn't happened. This is very straight forward testbench flow. Please help as I have been debugging for 3 days now.
  • muffi
    muffi over 6 years ago
    I do not see the package specified on the xrun command line. Importing a package does not compile it automatically. Packages have to be compiled before they are imported. Adding the soc_test_pkg.sv package to your command line before doc_tb_top.sv will resolve the NOPBIND error.
  • vujaclyn
    @muffi, thank you for your suggestion. I've added as below:
    xrun -uvmhome $(UVM_LIB_PATH) -uvm -64BIT +incdir+../src +incdir+../sim +incdir+../tests ../src/soc_tb_top.sv -seed $(SEED) -access +rwc ../tests/soc_test_pkg.sv ../src/soc_tb_top.sv
    Now getting this ERROR:
    TOOL: xrun(64) 20.03-s008: Started on Oct 19, 2020 at 10:58:29 PDT
    file: ../tests/soc_test_pkg.sv
    import uvm_pkg::*;
    xmvlog: *E,NOPBIND (../tests/soc_test_pkg.sv,10|15): Package uvm_pkg could not be bound.
    Now it's complaining about uvm_pkg could not be bound. Please help!!
  • vujaclyn
    vujaclyn over 6 years ago in reply to vujaclyn
    Here is the correct xrun cmd:
    xrun -uvmhome $(UVM_LIB_PATH) -uvm -64BIT +incdir+../src +incdir+../sim +incdir+../tests -seed $(SEED) -access +rwc ../tests/soc_test_pkg.sv ../src/soc_tb_top.sv
  • muffi
    muffi over 6 years ago in reply to vujaclyn
    What does ${UVM_LIB_PATH} point to? If you are using the UVM library from the Xcelium installation, you can use the option "-uvmhome CDNS-1.2" or "-uvmhome CDNS-1.1d".
    UNIX> xrun -uvmhome CDNS-1.1d -64BIT +incdir+../src +incdir+../sim +incdir+../tests -seed $(SEED) -access +rwc ../tests/soc_test_pkg.sv ../src/soc_tb_top.sv
    Do take a look at the following article on COS for more information on how to use the UVM library:
    FAQ: Frequently Asked Questions related to the UVM library, methodology, learning resources
  • vujaclyn
    vujaclyn over 6 years ago in reply to muffi
    Thank You for your help, really appreciated. Yes, UVM_LIB_PATH points to CDMS-1.2. I'm able to compile now, I have to add the following code for all packages which import uvm_pkg:
    `ifndef MY_PKG_EXCLUDE
    `define MY_PKG_EXCLUDE
      `include "uvm_pkg.sv"
    `endif
  • muffi
    You don't need the "`include "uvm_pkg.sv". In fact it will cause checksum issues and DLCSMD error if MY_PKG_EXCLUDE is defined, and you use -uvmhome or -uvm options. Packages are generally compiled and imported where needed. You should avoid tick including them.
