  2. Functional Verification
  3. vManager vAPI authentication
  • Subscribers 67
  • Views 17404
BGarcia
BGarcia over 5 years ago
Hello Support Team,
I have issues trying to use the vAPI, as it show an error that requires full authentication:
    <h2>HTTP ERROR 401</h2>
    <p>Problem accessing /vmgr/vapi/rest/sessions/list. Reason:
        <pre>    Full authentication is required to access this resource</pre>
I've looked into the documentation and I could not find what to pass as a parameter or any kind of token information for authentication.
Could you please help me how to authenticate or point me to the right documentation?
Best Regards,
Baudilio Garcia
  • StephenH
    StephenH over 5 years ago
    Hi Baudilio.
    It's telling you that you need to provide your credentials (username and password). What method are you using to make the request (e.g. are you using the Python "requests" module?).
    What happens if you try with "curl" at the Linux prompt, for example:
    Listing all session owners:
    curl -X POST "https://yourserver:8080/vmgr/vapi/rest/sessions/list" -H "accept: application/json" -H "content-type: application/json" -d '{ "filter": { "condition": "AND", "@c": ".ChainedFilter", "chain": [] }, "grouping": [ "owner" ], "pageOffset": 0, "pageLength": 50, "settings": {"write-hidden": true, "stream-mode": false }, "projection": { "type": "SELECTION_ONLY", "selection": ["owner" ] }}' -k -user ${USER}:yourpassword -v
    (replace <yourserver> and <yourpassword> of course). If you don't want to specify the password, omit the -u option and curl should prompt for your password interactively.
  • BGarcia
    BGarcia over 5 years ago in reply to StephenH
    Hi Stephen,
    I was just using Postman for it, which uses curl. Once providing the data for basic authentication it worked! Thanks for your help!
    Do you happen to have a call to list all sessions that are older than a specific date? I am trying to follow the examples in vmgr/vapi/examples/index.html?op=/sessions/list/POST but having some issues.
    Best Regards,
    Baudilio Garcia
  • StephenH
    StephenH over 5 years ago in reply to BGarcia
    Cool. Slight smile
    Here's a JSON for /sessions/list that works for me:
    "filter": {
    "attName": "start_time",
    "operand": "LESS_THAN",
    "@c": ".AttValueFilter",
    "attValue": "1605106174000"
    "projection": {
    "selection": [
    "owner", "name", "start_time"
    note the attValue field is the "date" expressed as milliseconds since the Unix Epoch. I tend to do all my scripting in Python and use the "time" module to make conversions easy, but you can achieve the same things with the Unix "date" command and a format string, for example:
    % date -d '2 weeks ago' '+%s000'
    1605693511000
  • BGarcia
    Works flawlessly. Amazing support as always, Stephen!
