  2. Functional Verification
  3. Tool to generate UVM RAL Model
  • Subscribers 67
  • Views 21326
sriganeshd
sriganeshd over 5 years ago
Hello All,
         I want to generate the UVM RAL Model from ".xml file"  or  ".csv file". what is the tool used for it and Procedure to generate RAL Model.!
  • hannes
    hannes over 5 years ago +1
    Hi, The term RAL is not used in UVM that much any more, so maybe you could not find it in the help. You can use reg_verifier (part of Xcelium) to translate IP-XACT register descriptions (.xml) into UVM…
  • hannes
    The term RAL is not used in UVM that much any more, so maybe you could not find it in the help. You can use reg_verifier (part of Xcelium) to translate IP-XACT register descriptions (.xml) into UVM register models. Have a look at this material: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009ESyXUAW&pageName=ArticleContent or search for uvm_reg or reg_verifier in the online docs
    All the best,
    -hannes
  • sriganeshd
    sriganeshd over 5 years ago in reply to hannes
    Thanks, Hannes.
