  2. Functional Verification
  3. Is there a way to view what line of HDL code is being executed...
  • Subscribers 67
  • Views 18664
Is there a way to view what line of HDL code is being executed at the moment in XMSim?
yavuzselim
yavuzselim over 5 years ago
I'm trying to run a behavioral simulation of my Verilog design, but somehow the Xmsim simulator seems to go into an infinite loop and the simulation stops advancing. It literally gets stuck. I was wondering if there is a way to view what line of Verilog code is being evaluated/executed at the time. Is this possible with Xmsim HDL simulator?
Thanks in advance.
  • StephenH
    StephenH over 5 years ago +1
    Yes, but you need to compile the design with -linedebug, then once the sim is stuck you can do Ctrl-C and it'll interrupt the simulation and tell you what line it's on. Often the hang is caused by a…
  • StephenH
    Often the hang is caused by a clock toggling with zero delay due to rounding errors with time precision, however there are many other possible causes.
    We have a good application note describing how to debug stuck simulations: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nTGDEA2&pageName=ArticleContent
  • yavuzselim
    yavuzselim over 5 years ago in reply to StephenH
    That worked. Thanks a lot Stephen.
