  2. Functional Verification
  3. license search order in Xcelium
  • Subscribers 67
  • Views 17776
Mugurel
Mugurel over 5 years ago
Our company used to have licenses for both Xcelium_Limited_Single_Core and Xcelium_Single_Core. Recently the management decided to only buy the last one. Now, when somebody tries to run xmverilog, it takes a very long time until it starts working. In the license server log I see the instance is trying six times to check out the 'limited' license ( not available) and eventually gives up and gets the second one. If there are multiple verilog files ... it is doing it for each. I was looking in the available switches, there is one called 'license_order', but is says it is obsolete. I cannot find any info on how to force it to check in the available license.
Is there a way to do that?
  • StephenH
    StephenH over 5 years ago
    Normally the license checking should be very fast and the order shouldn't matter, but if you're using the LM_LICENSE_FILE variable to point to multiple license servers from multiple vendors, it can slow things down. If possible, try using the CDS_LIC_FILE variable to point to the cdslmd server(s) only, and also set CDS_LIC_ONLY to stop Xcelium from using the LM_LICENSE_FILE settings.
  • Mugurel
    Thanks Stephen,
    This is what I ended up doing. It does speed up the checkout sequence, but... I would rather like to be in control of the license checked out. For the P&R tool, for example, we could specify the license ( like 'encounter -vdi'). Sometime is for speed, sometime for keeping a specific license available. I have seen the same thing in Virtuoso. With versions up to 6.1.7, opening a layout view would get the Virtuoso L licence, if available, and only if it was not it was getting the XL or GXL license. With 6.1.8, it gets directly the XL ( I do not have GXL). One circuit designer wants to verify a license... he gets the XL although he does not need it and the license is no longer available for a layout designer who will need it.
    Mugurel
