  2. Functional Verification
  3. Print only the file name and exclude file path getting printed...
  • Subscribers 67
  • Views 13398
Print only the file name and exclude file path getting printed in the log file
vijey
vijey over 5 years ago
Hello Everyone,
In the log file, The entire file path is printed instead of just the filename, This increases the log file size and also looks clumsy. Kindly let me know the option to pass, to disable the file path getting printed.
The log file has the below line,
UVM_INFO /design/users/vijay/icmanage_check/learn/uvm/tb/top.sv(28) @ 0: reporter [TOP] Calling RUN_TEST
Instead I would like the above line to look as below in the log file.
UVM_INFO top.sv(28) @ 0: reporter [TOP] Calling RUN_TEST
Thanks in advance
Vijay
  • StephenH
    StephenH over 5 years ago
    I don't think UVM has a built-in way to do that, but you could derive your own report server from uvm_report_server and override the compose_message() function to modify the file name.
