  2. Functional Verification
  3. How to use variable array in laplace_nd function?
  • Subscribers 67
  • Views 12757
bikram94
bikram94 over 5 years ago
I have written a verilog-A model of a filter.
cap_arr[0]=1;
cap_arr[1]=RC;
res_arr[0]=feed_res;
res_arr[1]=0;
V(OUTM)<+ laplace_nd(I(INP),res_arr, cap_arr);
V(OUTP)<+ laplace_nd(I(INM),res_arr, cap_arr);
total sims time 5us
the value of RC and feed_res are changing with time
0s to 1us Value of RC=1e-18 and reed_res=0.1
1us to 5us Value of RC=560e-12 and reed_res=500
now The output I am getting is the same at entire sims. It should change at 1us
The output is generating depending on the initial values of the res_arr and cap_arr.
Is there any way to make the laplace_nd function take the array variable at every abstime?
Thank you.
