  2. Functional Verification
  3. Fresh Incisive installation using IScape
  • Subscribers 67
  • Views 15192
musazal
musazal over 5 years ago
Hey there, newbie here. Hope you are all doing well. I'm trying to install Incisive using IScape. I have downloaded the Incisive package (contained on 4 tar files) manually (directly from the site page) and now trying to install it from IScape. But when I select the Local Directory/Media Install and then select the location where I downloaded Incisive (like /home/Downloads etc.), it gives the error
The directory selected is not a Cadence download location. Select a good Cadence download location
in case of Original GUI option in preferences and
/root/cadence/downloads
Does not seem to be a good Cadence installation directory
in case of New GUI option in preferences.
Can anybody help me solve this. I'll appreciate it.
  • StephenH
    StephenH over 5 years ago
    Are you running installscape on a supported OS? It's quite challenging to figure out what might have gone wrong, based on your description above. It might be best if you could login to support.cadence.com and file a support ticket so that one of the hotline team can assist you over a shared screen.
  • musazal
    musazal over 5 years ago in reply to StephenH
    I'm trying to run it on WSL2. But at least the download should work, shouldn't it? I know that supported OS is CentOS 7 but I was looking for a way to run it on Ubuntu type system.
  • StephenH
    StephenH over 5 years ago in reply to musazal
    We don't support Ubuntu, and I'm aware that Ubuntu is normally missing a bunch of dependencies (OS packages) that Cadence tools rely on. Sometimes you can figure these out and install them manually, but I don't have a detailed guide for that process.
  • musazal
    Thanks for replying. I understand now. So, is there a way to close this question or should I just leave it as it is?
