  2. Functional Verification
  3. xmsim/BSSXCD = The element count of bit-stream has reached...
  • Subscribers 67
  • Views 3095
xmsim/BSSXCD = The element count of bit-stream has reached to a value that can cross the integer range in case anymore element gets added to bit-stream
Nandeesha
Nandeesha over 5 years ago
Hi
Here is my issue:
I have regenerated the register bank and register map for the updated xml (New registers have been added). The compilation is clean but when I run the simulation, it halts at ZERO time with the following error. [img][/img]
xmsim: *E,BSSXCD (/sw/cadence/xcelium/20.03.002/lnx86/tools/methodology/UVM/CDNS-1.2/sv/src/base/uvm_printer.svh,1118|17): No more element can be added to bit-stream - current size is [268433520] and further addition will cross the maximum permissible limit [268435455]. File: /sw/cadence/xcelium/20.03.002/lnx86/tools/methodology/UVM/CDNS-1.2/sv/src/base/uvm_printer.svh, line = 1118, pos = 17
Below is the uvm_table_printer function and I have added a comment at the error line (//ERROR LINE). You can also refer to this function in http://www.studio-muzzi.com/project/docs/UVMdocs_smu/uvm-1.1d/uvm__printer_8svh_source.html (Line 973-1055)
function string uvm_table_printer::emit();
  string s[$];
  string user_format;
  static string dash; // = "---------------------------------------------------------------------------------------------------";
  static string space; //= "        ";
  string dashes;
  string linefeed = {"\n", knobs.prefix};
  calculate_max_widths();
   begin
      int q[5];
      int m;
      int qq[$];
      q = '{m_max_name,m_max_type,m_max_size,m_max_value,100};
      qq = q.max;
      m = qq[0];
  	if(dash.len()<m) begin
  		dash = {m{"-"}};
  		space = {m{" "}};
  	end
  end
  if (knobs.header) begin
    string header;
    user_format = format_header();
    if (user_format == "") begin
      string dash_id, dash_typ, dash_sz;
      string head_id, head_typ, head_sz;
      if (knobs.identifier) begin
        dashes = {dash.substr(1,m_max_name+2)};
        header = {"Name",space.substr(1,m_max_name-2)};
      end
      if (knobs.type_name) begin
        dashes = {dashes, dash.substr(1,m_max_type+2)};
        header = {header, "Type",space.substr(1,m_max_type-2)};
      end
      if (knobs.size) begin
        dashes = {dashes, dash.substr(1,m_max_size+2)};
        header = {header, "Size",space.substr(1,m_max_size-2)};
      end
      dashes = {dashes, dash.substr(1,m_max_value), linefeed};
      header = {header, "Value", space.substr(1,m_max_value-5), linefeed};
      s.push_back({dashes, header, dashes});
    end
    else begin
      s.push_back({user_format, linefeed});
    end
  end
  foreach (m_rows[i]) begin
    uvm_printer_row_info row = m_rows[i];
    user_format = format_row(row);
      string row_str;
        row_str = {space.substr(1,row.level * knobs.indent), row.name,
                   space.substr(1,m_max_name-row.name.len()-(row.level*knobs.indent)+2)};
        row_str = {row_str, row.type_name, space.substr(1,m_max_type-row.type_name.len()+2)};
      if (knobs.size)
        row_str = {row_str, row.size, space.substr(1,m_max_size-row.size.len()+2)};
      s.push_back({row_str, row.val, space.substr(1,m_max_value-row.val.len()), linefeed});
    end
    else
  end
  if (knobs.footer) begin
    user_format = format_footer();
      s.push_back(dashes);
    else
  end
  begin
	  	string q = {>>{s}}; //ERROR LINE line = 1118, pos = 17
  		emit = q;
  end
  m_rows.delete();
endfunction
Here is the sample of my regbank (There are many registers in this maps )
this.STATUS_file = STATUS_file_type::type_id::create("STATUS_file", null, get_full_name());
this.STATUS_file.configure(this,null,$sformatf("STATUS_file"));
this.STATUS_file.build();
this.STATUS_file.map(this.shibuya_regbank_mcu_map,`UVM_REG_ADDR_WIDTH'h0);
this.DIAG_STATUS_file = DIAG_STATUS_file_type::type_id::create("DIAG_STATUS_file", null, get_full_name());
this.DIAG_STATUS_file.configure(this,null,$sformatf("DIAG_STATUS_file"));
this.DIAG_STATUS_file.build();
this.DIAG_STATUS_file.map(this.shibuya_regbank_mcu_map,`UVM_REG_ADDR_WIDTH'h224);
It's really hard time for me to debug this issue. Please give me some inputs on what might be going wrong. I confirm to you that all the registers are with in the specified range. I don't understand what it has to do with the printing. I don't know how to increase/configure the bit-stream size.
Thanks in advance.
  • muffi
    muffi over 5 years ago
    Hi Nandeesha,
    This BSSXCD error is issued when a very large UVM hierarchy is printed using uvm_top.print_topology().
    You will also see this message if you are trying to print an object using `uvm_info or uvm_report_info() and the size of the bit-stream exceeds the maximum permissible limit [268435455]
    As the error message states, the maximum permissible limit for the bit-stream size is 268435455. If the topology print crosses this limit, you can comment out the print_topology()call to avoid the error. If the error is due to printing a huge object, then consider reducing the number of elements being printed by using the UVM_NOPRINT automation flag to exclude a field for printing.
    The Verilog Stack Trace that is printed along with the error message will point you to the location of code which is causing the error.
    Please take a look at the following article on https://support.cadence.com where this is documented.
    Article (20479996) Title: How to prevent BSSXCD error when uvm_topology or uvm_info print exceeds the max permissible limit
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V0000090tKfUAI
    Thanks.
