  2. Functional Verification
  3. How do I map signal values to meaningful string in simvision...
  • Subscribers 67
  • Views 18817
How do I map signal values to meaningful string in simvision?
avidanefody
avidanefody over 5 years ago
i.e. how do I do something like what's described here for the competition:
electronics.stackexchange.com/.../is-there-a-way-to-define-enumeration-for-certain-signals-after-simulation
(I'd like to do this from a TCL command if possible)
Thanks!
  • StephenH
    StephenH over 5 years ago +1
    I haven't followed the link you posted as I'm not mad keen on following arbitrary links people post in forums, but I believe you want the mnemonic map feature in SimVision. This can be done via the GUI…
  • StephenH
    StephenH over 5 years ago in reply to avidanefody +1
    The simplest way is to run the Tcl script in SimVision to create the map, thereafter you can right click on the value for a signal in the waveform, and instead of changing radix, select the map name. …
  • StephenH
    I haven't followed the link you posted as I'm not mad keen on following arbitrary links people post in forums, but I believe you want the mnemonic map feature in SimVision. This can be done via the GUI then saved to a Tcl script for reuse, or you can use the raw Tcl commands in SimVision to build the maps programmatically.
    Refer to https://support.cadence.com/apex/techpubDocViewerPage?xmlName=simvistclcmds.xml&title=SimVision%20Tcl%20Commands%20--%20Contents%20-%20&hash=&c_version=21.03&path=SimVisTclCmds/SimVisTclCmds21.03/SimVisTclCmdsTOC.html for the SimVision Tcl commands (make sure you enter these at the SimVision Tcl prompt not the Xcelium Tcl prompt).
    Pasting an example from the above docs link:
    mmap new -name "Current State" -contents {
        {‘d0 -label "idle"}
        {‘d1 -label "five"}
        {‘d2 -label "ten"}
        {‘d3 -label "fifteen"}
        {‘d4 -label "twenty"}
        {‘d5 -label "twenty-five"}
        {‘d6 -label "thirty"}
        {‘d7 -label "thirty-five"}
        {‘d8 -label "forty"}
        {‘d9 -label "forty-five"}
        {‘d10 -label "fifty"}
        {‘d11 -label "nickel_out"}
        {‘d12 -label "dime_out"}
        {‘d13 -label "two_dime_out"}}
  • avidanefody
    avidanefody over 5 years ago in reply to StephenH
    @stephenh no need to click your guess was good enough :-)...ok, so I created a mnemonic map, now what? how do I attach it to a signal in the waveform so that it shows these values instead of the numeric ones?
  • StephenH
    Example at the bottom of this app note: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nWEkEAM&pageName=ArticleContent
  • avidanefody
    That works! thanks
