  2. Functional Verification
  3. I would like to see the values of a signal after some mathematical...
  • Subscribers 67
  • Views 2240
I would like to see the values of a signal after some mathematical/logical function. How do I do this?
avidanefody
avidanefody over 5 years ago
Looking for a way to run a TCL procedure over all values of a signal, and if possible display these values in the wave on another "virtual" signal.
For example:
I would like to do the following transformation
limit_values = [0, 50, 100, 300, 400]
signal_values = [20, 60, 90, 220, 5000]
after transformation:
new_values = [0, 50, 50, 100, 400]
Basically finding the nearest lowest value to the signal value in the limit_values table.
  • StephenH
    StephenH over 5 years ago +1
    You probably want the expression calculator for this, as it lets you define a Tcl expression to compute a new signal derived from one or more other signals: https://support.cadence.com/apex/techpubDocViewerPage…
  • StephenH
    You probably want the expression calculator for this, as it lets you define a Tcl expression to compute a new signal derived from one or more other signals: https://support.cadence.com/apex/techpubDocViewerPage?xmlName=expressioncalculator.xml&title=SimVision:%20Using%20the%20Expression%20Calculator%20--%20Contents%20-%20&hash=&c_version=21.03&path=ExpressionCalculator/ExpressionCalculator21.03/ExpressionCalculatorTOC.html
    There is also a cheat-sheet for the expression syntax here:
    https://support.cadence.com/apex/techpubDocViewerPage?path=expression_qrg/expression_qrg21.03/expression_qrgTOC.html
    To build a look-up table per your request, I think the simplest thing would be to build a tree of ternary expressions, something like:
    (mysig < 50) ? 0 : (mysig < 100) ? 50 : (mysig < 300) ? 100 : (mysig < 400) ? 300 : 400
