  2. Functional Verification
  3. Reading simulation time to a variable
  • Replies 17
  • Subscribers 67
  • Views 25596
Pedro Cardoso
Pedro Cardoso over 4 years ago
Does anyone know if it is possible to read the running time and, then store it into a variable using TCL?
Imagine that a simulation is running. Every time it is simulating the time moves, when it's not the time doesn't. With this, I would like to retrieve the real simulation time.
Thanks in advance.
Kind regards,
Pedro
  • Pedro Cardoso
    Pedro Cardoso over 4 years ago in reply to StephenH
    Hi Stephen,
    But how do I tell xrun where to stop and measure the time?
    Please note that I am entering my commands in the console.
    Cheers,
    Pedro
  • Pedro Cardoso
    Hi Stephen
    I cannot make this work.
    So, do I have to call xrun as "xrun -status -status3" or as "xrun -status -status 3" ?
    Am I missing something?
    Best regards,
    Pedro
  • StephenH
    StephenH over 4 years ago in reply to Pedro Cardoso
    Hi Pedro.
    It's the first one: "xrun -status -status3".
    The "-status" tells it to dump a CPU/memory summary at exit, and "-status3" tells it to dump the more verbose version of the summary, with a break-down for the individual tool components.
  • Pedro Cardoso
    Thanks for the answer.
    But how does the simulator know when to dump the summary ? I should have to write some command to tell the simulator that I want to generate the report at that point of the code.
    Otherwise, how xrun would know that the program had ended?
  • Pedro Cardoso
    Hi Stephen,
    Can you please give me your inputs on my last question? I would really appreciate it.
    Best regards,
    Pedro
  • StephenH
    The summary is dumped when you exit the simulator.
  • Pedro Cardoso
    This is the output I have
    Aggregate audit (2:30:10 PM, Fri Dec 10, 2021):
    Time used: CPU = 47.9 ks (13h 18m 36s), elapsed = 13 ks (3h 36m 17s), util. = 369%.
    Time spent in licensing: elapsed = 20.6 s.
    Peak memory used = 2.33 Gbytes.
    Simulation started at: 10:53:53 AM, Fri Dec 10, 2021, ended at: 2:30:10 PM, Fri Dec 10, 2021, with elapsed time (wall clock): 13 ks (3h 36m 17s).
    spectre completes with 0 errors, 89 warnings, and 22 notices.
    xmsim: Memory Usage - Final: 1289.0M, Peak: 1345.3M, Peak virtual: 1734.9M
    xmsim: CPU Usage - 3314.5s system + 46984.3s user = 50298.8s total (14821.7s, 100.0% cpu) (myhost)
    xrun: Time - 15071.8s
    TOOL: xrun(64) 20.05-t004-20201018: Exiting on Dec 10, 2021 at 14:43:02 CET (total: 04:11:12)
    Do I have to divide the time, returned by the simulator, by the number of cpus I've used? Otherwise, the result doesn't make sense.
    15071 seconds is 4.18h, which is more than the "wall clock" value.
