  2. Functional Verification
  3. Reading simulation time to a variable
  • Replies 17
  • Subscribers 68
  • Views 26052
Pedro Cardoso
Pedro Cardoso over 5 years ago
Does anyone know if it is possible to read the running time and, then store it into a variable using TCL?
Imagine that a simulation is running. Every time it is simulating the time moves, when it's not the time doesn't. With this, I would like to retrieve the real simulation time.
Thanks in advance.
Kind regards,
Pedro
  • StephenH
    StephenH over 5 years ago
    Hi Pedro.
    The "time" command lets you report the current time, as well as doing math operations on time values. Refer to the Xcelium Tcl docs.
    xcelium> time
    0 FS
    xcelium> time ns
    0 NS
    xcelium> set now [time ns]
    0 NS
    xcelium> puts $now
    0 NS
    xcelium>
  • Pedro Cardoso
    Pedro Cardoso over 5 years ago in reply to StephenH
    Is there a way to read the time value while the script is running using interruptions?
    Imagine that I want to use the command time and clock every 10seconds. Is that possible?
    Pedro
  • StephenH
    StephenH over 5 years ago in reply to Pedro Cardoso
    There's no built-in way to set a real-time breakpoint, but it could be done by writing some C code to set an OS timer interrupt and some VPI code to get the timestamp and print it.
    Alternatively just set a breakpoint that stops the simulation every N time units of simulated time and use the Tcl "clock" command to print the current time, would that help?
    stop -create -time -relative 10ns -continue -execute { set now [time ns]; clock format [clock seconds] -format "TICK: $now == %T"; }
  • Pedro Cardoso
    Thanks for your reply.
    I tried the command above the following way:
    1 - entered the "stop" command
    2 - entered "after 5000"
    I was expecting to have interruptions during the execution of the command "after 5000", but that doesn't happen.
    Pedro
  • StephenH
    The "stop" command doesn't accept a "after" argument so I don't understand what you did here (nor what you mean by "after 5000").
    The time-related brakpoint options are:
    -time time_spec  [-absolute]  [-relative]  [-start time_spec ]  [-modulo time_spec]
    please check the docs that I linked to in my first reply, everything you need is in there. Slight smile
  • Pedro Cardoso
    The "time" that the stop command will generate is the CPU time. I would like to stop every 10 seconds (human time).
  • StephenH
    As I mentioned before, there is no built-in way to stop based on real time, only simulated time can be specified with the stop command. What are you actually trying to achieve? If you can explain that, maybe I can propose a way to do it based on what is supported int eh simulator...
  • Pedro Cardoso
    I am trying to measure the time a simulation takes to run, but without taking into account the time the simulator is doing nothing.
    So if I run a piece of code that takes 10 minutes and go for lunch for an hour and then run another piece of code that takes 10 minutes more, I would like the reported duration of the sim to be 20 minutes and not 1h:20m.
  • StephenH
    OK, thanks for clarifying your request. If you just need this time measurement as a summary for the entire simulation, why not just add "-status -status3" to the xrun command line? This will result in a couple of lines at the end of the simulation log, including the actual CPU time spent:
    xmsim: CPU Usage - 26.2s system + 31.0s user = 57.2s total (86.4s, 66.2% cpu) (myhost)
    xrun: Time - 87.0s
    Here you can see that the simulation used 87.0s of CPU time - this is not the wall-clock time but the time used actually doing work.
  • Pedro Cardoso
    Thank you very much. I will try this.
    Pedro
