  2. Functional Verification
  3. report unused verilog packages
  • Subscribers 68
  • Views 14987
Max Bjurling
Max Bjurling over 4 years ago
Is there any tool from Cadence that can report unused Verilog packages?
Often the import MyPackage::* statements are left at the top of a module declaration even though the code that was using them has been removed from the module. This causes unnecessary dependencies that may not be detected. So can I get a report of such unused packages from xmelab, JasperGold, Genus, or any other Cadence tool?
Max
  • StephenH
    StephenH over 4 years ago +1
    Hello Max. I'm not aware of a built-in way to do this in Xcelium and am not an expert in the other tools like Genus. I can see a way to do this in Xcelium, using a bit of Tcl scripting. Just for fun…
  • StephenH
    Hello Max.
    Just for fun, as it's Friday afternoon, I played around and built an example for you:
    File: pkg_ref_test.sv
    Run with:
      xrun -clean pkg_ref_test.sv -input "@source chk_pkgs.tcl;chk_pkgs top;exit" ; cat pkgs.log
    package p1;
      parameter P1P = 1;
      typedef enum bit {OK,BAD} p1e;
    endpackage
    package p2;
      localparam P2P = 2;
      class p2c;
        bit b;
      endclass
    endpackage
    module m;
      import p1::*;
      import p2::*;  // redundant
      bit [P1P-1:0] data;
      p1e myenum;
      initial $display(P1P);
    endmodule
    module top;
      m u_m();
    endmodule
    And the script:
    # File: chk_pkgs.tcl
    proc chk_pkgs {top} {
      scope -set $top
      set ofile [open {pkgs.log} "w"]
      puts $ofile "Starting with $top"
      foreach inst [find -instances * -recursive all -absolute] {
        puts $ofile "Checking $inst"
        puts $ofile [describe $inst]
        scope -set $inst
        set desc [scope -describe]
        regexp -line {Dependent packages (.*)\n} $desc -> pkglist
        set pkglist [regexp -all -inline {[a-zA-Z0-9_]+} $pkglist]
        puts $ofile "$inst references packages ($pkglist)"
        # Iterate all the package-qualified names in the scope
        set refs [regexp -all -inline {([a-zA-Z0-9_]+)::[a-zA-Z0-9_]} $desc]
        set num_refs [llength $refs]
        array unset refpkgs
        array set refpkgs {}
        for {set i 1} {$i<$num_refs} {incr i 2} {
          set refpkgs([lindex $refs $i]) 1
        puts $ofile "Used packages: [array names refpkgs]"
        foreach p $pkglist {
          set matches [array names refpkgs -exact $p]
          if {$matches == ""} {
            puts $ofile "Package $p was NOT used in $inst"
          } else {
            puts $ofile "Package $p is required by $inst"
      puts "Done"
      close $ofile
    Run it with the xrun command listed in the SV file, and you should get an output file "pkgs.log" listing each design instance and which packages are used or not used.
    Starting with top
    Checking top.u_m
    top.u_m....instance of module m
    top.u_m references packages (p1 p2)
    Used packages: p1
    Package p1 is required by top.u_m
    Package p2 was NOT used in top.u_m
    It's probably not the most efficient or pretty Tcl code, but hopefully this helps solve your requirement! There is scope to optimise it by caching the results per-module and skipping repeated module instances, but I leave that as an exercise for you ;-)
    Steve
  • Max Bjurling
    Max Bjurling over 4 years ago in reply to StephenH
    Wow, thanks a lot! This was really helpful.
    The scope -set $inst command fails if $inst is an instance array, but I added a catch to get further:
    if { [catch {scope -set $inst}]} {
      puts "skipping $inst"
      continue
    Then I will probably add the code to avoid analysing and reporting the same module multiple times, like you suggested.
    Thanks again!
    Max
  • StephenH
    StephenH over 4 years ago in reply to Max Bjurling
    Thanks for the feedback Max.
    Here's a version that handles instance arrays as well:
      scope -set $top
        puts $ofile ">>>>>>>"
        if { [catch {scope -set $inst}] } {
          # catch instance arrays
          if { [regexp {instance array \[\d+:(\d+)\]} [describe $inst]  -> lowerbound] } {
              puts "Found array instance $inst"
              set inst "$inst\[$lowerbound\]"
              puts "Trying to index into array instance: $inst"
                puts "Failed, skipping $inst"
                continue
          } else {
            puts "Skipping $inst"
            continue
        array unset refpkgs
          } else {
      puts "Done"
      close $ofile
  • Max Bjurling
    Thanks again! I have added the code to only report each module once, and some minor corrections:
    # list all unused packages
    # This script is based on the script provided by StephenH in the Cadence
    # Functional Verification forum:
    # community.cadence.com/.../report-unused-verilog-packages
    proc list_unused_packages {top} {
        scope -set $top
        set logfile_name "./log/list_unused_packages.log"
        set ofile_name "./report/${top}_unused_packages.txt"
        set logfile [open $logfile_name "w"]
        set ofile [open $ofile_name "w"]
        puts "Listing unused packages in $top and subdesigns."
        puts "  Report file: ${ofile_name}"
        #puts "  Log file: ${logfile_name}"
        puts ${ofile} "--------------------------------------------------------------------------------"
        puts ${ofile} "Unused packages in $top and submodules"
        set insts [concat $top [find -instances * -recursive all -absolute]]
    #    lappend insts $top
        foreach inst $insts {
            puts $logfile ">>>>>>>"
            puts $logfile "Checking $inst"
            set dscr [describe $inst]
            puts $logfile $dscr
            # module/interface name is the last word in description
            set mod [lindex $dscr [expr [llength $dscr] - 1] ]
            # Top level module is descibed differently
            if {$mod eq "module"} {
                set mod [lindex [split $dscr {.}] 0]
                    puts $logfile "Found array instance $inst"
                    puts $logfile "Trying to index into array instance: $inst"
                        puts $logfile "Failed, skipping $inst"
                        continue
                } else {
                    puts $logfile "Skipping $inst"
                    continue
            if { ![info exists modules($mod)] } {
                puts $logfile "Analyzing module $mod"
                puts $logfile [scope -describe]
                set pkglist {}
                puts $logfile "$inst references packages ($pkglist)"
                array unset refpkgs
                puts $logfile "Used packages: [array names refpkgs]"
                        puts $ofile "$mod : $p"
                        puts $logfile "Package $p is NOT used in $inst"
                    } else {
                        puts $logfile "Package $p is required by $inst"
                set modules($mod) 1
            } else {
                puts $logfile "Already analyzed module $mod"
        puts "Done"
        close $logfile
        close $ofile
