  2. Functional Verification
  3. How to remove glitch from Asynchronous UVM TB?
  • Subscribers 68
  • Views 12071
Mahesht6
Mahesht6 over 4 years ago
Hi All,
In our UVM_TB, driver is full of fork join and we drive addr, cmd and data.
We are using cadence, xcelium tool.
Enabled the event while probing for simvision to see the glitch:
probe  -default  -event
In the simulation, I see for every data that we write on data bus, there is a glitch and it is present thorugh out the simulation.
Can you pleaes suggest the possible solutions to fix these glitches?
Thanns in advance,
  • StephenH
    StephenH over 4 years ago
    This is a very abstract question, so it's hard to answer. You should probably open a support requet on the support.cadence.com site so that you can arrange a screen share with one of the hotline team, unless you can give us a more detailed explanation and ideally a runnable example.
